ClickSend TTS
The clicksend_tts
platform uses ClickSend to deliver text-to-speech (TTS) notifications from Home Assistant.
After creating your account, you should now be able to obtain your username
and api_key
here.
To add ClickSend to your installation, add the following to your Home Assistant configuration.yaml
The configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI.[Learn more] file:
notify:
- platform: clicksend_tts
username: CLICKSEND_USERNAME
api_key: CLICKSEND_API_KEY
recipient: PHONE_NO
Setting the optional parameter name allows multiple notifiers to be created. The notifier will bind to the service notify.NOTIFIER_NAME.
An E.164 formatted phone number, like +14151234567
. This is the phone number that you want to call and notify via TTS, see ClickSend Documentation for more info.
The language you want to use to convert the message to audio. Accepted values are found in the ClickSend Documentation.
Usage
ClickSend is a notify platform and thus can be controlled by calling the notify service as described here. It will send a notification to the E.164 phone number you configured as recipient.
alias: "The sun has set"
trigger:
- platform: sun
event: sunset
action:
- service: notify.clicksend_tts
message: "The sun has set"
