Local to-do
The Local to-do list integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to create to-do lists in Home Assistant. To-do lists are shown on the To-do list dashboard for tracking items and whether or not they have been completed.
See the To-do list integration for additional details about to-do list entities.
To add the Local to-do integration to your Home Assistant instance, use this My button:
From the list, select Local to-do.
