Danfoss Air
The Danfoss Air integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to access information from your Danfoss Air HRV unit.
Note: Danfoss Air CCM only accepts one TCP connection at a time. Due to this the integration will not work while you have the HRV PC-Tool open.
To enable Danfoss Air, add the following lines to your configuration.yaml
danfoss_air:
host: IP_ADDRESS_OF_CCM
Binary sensor
The following binary sensor is supported.
- Bypass active: Indicator if heat recovery is currently bypassed.
Sensor
The following sensors are supported.
- Outdoor temperature: Outdoor air temperature.
- Supply temperature: Air temperature of the air supplied to the house.
- Extract temperature: Air temperature of the air extracted from the house.
- Exhaust temperature: Exhausted air temperature.
- Remaining filter lifetime: Remaining filter lifetime measured in percent.
- Humidity: Relative humidity in percent.
- Fan step: Fan step.
- Exhaust fan speed: Exhausted fan speed.
- Supply fan speed: Supply fan speed.
- Dial battery: Dial battery level in percent.
Switch
The following switches are supported.
- Boost: Switch to manually activate boost.
- Bypass: Switch to manually activate bypass.
- Automatic bypass: Switch to enable automatic bypass.
